Bought and rebuilding a b18c1. Info would be awesome.
Old Sep 19, 2014 | 09:54 PM
tagar89's Avatar
Default Bought and rebuilding a b18c1. Info would be awesome.
New to hondas, so far this is what the motor came with when i bought it
Skunk2 74mm throttle body
Skunk2 pro series intake manifold
B16 pistons
Arp studs
Dual valve springs with titanium retainers
75lb seat pressure @1.320
How high do you think this thing can turn (rpm)
Any guestimates on any numbers?
Old Sep 19, 2014 | 10:00 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: Bought and rebuilding a b18c1. Info would be awesome.
Drive it and see what it does. Why you rebuilding?
Old Sep 19, 2014 | 10:12 PM
tagar89's Avatar
Bought it as an investment really. gsr 4 door with jdm front end and the engine for a steal.
It came to me boosted on 9 lbs with low compression on cylinder 1,
Its obviously all good stuff so i figured id rebuild it and sell it. Motor already has tons of work done. Figured someone could use a nice piece instead of some gamble from over seas.
Old Sep 19, 2014 | 10:22 PM
Ferio Wdm Edition
Ohh alright. Well fix the compression. Its either a valve thats bent, or rings are bad. Fix that. You can probably sell it back just like that and make money off of it.
Old Sep 19, 2014 | 10:30 PM
tagar89's Avatar
Its the rings. Heads down getting a valve grind now. Ill be tearing apart the block monday
Old Sep 20, 2014 | 06:26 AM
blackeg's Avatar
stock gsr rods? or are those arp rod bolts?
ive seen stock rods with arp bolts go in the 9500 rpm range but its totally a waste if the cams dont make power there. what cams did it come with. also i think 74mm tb is a bit overkill
Old Sep 22, 2014 | 10:03 PM
tagar89's Avatar
Stock p72 rods with stock bolts
Pr3 pistons, every single one of them had cracked ring lands.
Anybetter suggestion on pistons or should i just stick with pr3s? Not looking to spend to much money.
74mm came with it along with everything else listed.
Not sure on the cam yet, i took them off but didnt even care to take a peak.
Old Sep 22, 2014 | 10:26 PM
ef2_civic's Avatar
74mm what?
And who ever is going to be rebuilding it should double check the Pistons. Just to be sure
Old Sep 22, 2014 | 10:54 PM
Ferio Wdm Edition
74mm trottle body is overkill. I got type r pistons. Everyone loves type r stuff lol, pm me if interested.
Old Sep 28, 2014 | 11:37 PM
tagar89's Avatar
Yea i know, its just what came with it. I messaged you but got nothing.
Ef civic, if you read some of the messages i think you will find what youre looking for.
Thomas
Old Oct 6, 2014 | 07:24 AM
Ferio Wdm Edition
Messaged who?
Hows the rebuild?
tagar89
Jun 27, 2015 09:34 PM
tagar89
Aug 8, 2014 04:55 PM
2000EM1will
Engine Management and Tuning
Jun 28, 2011 02:40 PM
godzhand
Jun 19, 2010 03:00 PM
AnthraxVX
Aug 9, 2006 12:06 PM
