Car Starting Mystery
Old Sep 19, 2014 | 08:22 AM
audieannie's Avatar
Icon3 Car Starting Mystery
I come to you, all mighty honda tech forums with something my local mechanics can't seem to figure out. Hopefully we can figure out what's wrong with my car
Car: 2003 Honda Civic EX Manual
Problem: The car is inconsistent on when it will start and when it will not.
Attempted Solutions:
      The mechanic says it might be the starter, but it is an expensive thing to guess about. Otherwise, he says my car is working fine.
      I guess my issue is, it doesn't make sense to me that it would be the starter having the issues if I can jump the car and get it going that way. AND it seems to be working after a longer than 5 min. drive
      Any ideas on why the tests would be coming back fine if obviously things are not fine? Does it sound like a starter issue?
      Old Sep 24, 2014 | 06:56 PM
      PyroProblem's Avatar
      Default Re: Car Starting Mystery
      Get yourself a voltmeter. Your starter needs only 3 things to work. Power, ground, and a signal to "start".
      A starter should be easy to diagnose. If these mechanics can't perform simple diagnostics on a starter, run away!
      What do mean by not "starting" ? As in not cranking?
      Old Sep 26, 2014 | 07:13 PM
      VegasInvasion's Avatar
      I'm Huge In Japan
      not a tuning issue. moving to general tech
      ttswimmer
      Honda Civic (2001 - 2005)
      Dec 23, 2015 05:41 AM
      adam00
      Feb 2, 2009 03:32 PM
      rawsx
      Mar 10, 2008 10:41 AM
      SOKDO
      Jun 2, 2005 10:33 AM
      94HybridEX
      Oct 10, 2002 10:06 AM
