Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2009 Honda Civic Clunk when braking... Suggestions Please
Old Sep 19, 2014 | 03:11 AM
hampshire32000's Avatar
Default 2009 Honda Civic Clunk when braking... Suggestions Please
I have a 2009 Honda Civic that is making a single clunk noise when breaking sort of hard. The noise is coming from the front drivers side engine / wheel area. The car has 120,000 miles on it and no front end work has ever been done and/or not accidents. You can slightly feel the clunk as well. Any ideas are welcome. I know that there is an issue with subframes needing work on Civics, however; I am not sure if this affects the 2009 model year.
Old Sep 19, 2014 | 04:01 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 2009 Honda Civic Clunk when braking... Suggestions Please
You should definitely not try to inspect it or have it inspected.
Old Sep 19, 2014 | 07:01 AM
DaveSi677's Avatar
it could be a million different possibilities... only way is to get under and look.
When was the last time the brakes were done/changed?
If done recently were the wheels torqued to spec? Check to make sure your lug nuts are properly seated and tightened as this could cause a certain sound which is similar to what you are describing... when the wheel is smacking against a part of the rotor.
A few other possibilities also but these of the first 2 I would be looking at.
Old Sep 19, 2014 | 06:10 PM
97emsedan's Avatar
I bet you the caliper bracket is fractured. If the caliper isn't firmly supported, it will rotate with the rotor until it binds.
fptquangngai
Mar 17, 2016 09:58 AM
Rokittt
Jul 29, 2014 02:24 PM
Darren E
Honda Civic (2001 - 2005)
Aug 19, 2013 07:32 PM
Integra4lyfe069
Jan 1, 2009 02:45 PM
postman
Dec 5, 2005 03:29 PM
