No turn signals, dash lights, tail lights
Old Sep 18, 2014 | 10:16 PM
Soulman41's Avatar
Default No turn signals, dash lights, tail lights
I have a 2002 Accord 4 door. Dash lights, tail lights, turn signals don't work. All of these stopped working at the same time. The car sat for about 2 months. The rest of the lights work fine. What should I check.
Old Sep 19, 2014 | 05:55 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: No turn signals, dash lights, tail lights
Blown fuses. Check under hood fuse box, and cabin fuse box. Gargoyle for 1998-2002 service manual pdf.
Old Sep 21, 2014 | 11:40 PM
Soulman41's Avatar
Does the same fuse control all of these or are they separate fuses?
Old Sep 22, 2014 | 07:05 PM
belairbrian's Avatar
Separate fuses but all 3 circuits use ground G401. but that should cause other problems. It's on the left of the drivers foot well.
P.s. Follow Mike's suggestion. A little searching is well worth it.
Old Sep 25, 2014 | 10:00 AM
tunganhdo's Avatar
After checking the fuses, maybe you want to check the hazard light switch wiring next to the clock. One thing I noticed when I remove the switch to replace the clock, my lights wont work.
Gatschet
23
Aug 25, 2021 10:35 AM
slammed em1
Jan 23, 2010 09:26 PM
95silverteg
Sep 30, 2008 04:48 AM
