H2b
Will you be boosting? What are your goals?..Track or street setup? Need more info man
I've got this swap in my Civic right now.
I didn't have to cut the frame rail, but you'll need to delete the balance shafts, and get the balance shaft pulley machined down into a spacer. the fitment is tight, i can't change my alternator belt without removing my driver side mount.
H2B FAQ click here
H2B Discussion thread click here
If you order the KStuned balance shaft eliminator kit it comes with a new spacer. Otherwise there is a a spacer in the h2b sticky that can be used.
H2B FAQ click here
H2B FAQ click here
I made a balance shaft delete for under $20.
The machine work for the balance shaft pulley, plus getting the crank pulley machined down into a single pulley, cost about $60.
It's a little more cost effective and functions the same.
There's a $20 balance shaft delete thread somewhere.
If you are going NA, most people can get >250whp with a bone-stock bottom end. You definitely need to give more info on what car you have, what your goals are, etc.
Accord f22 crank pulley machined, ac and ps removed
I also had a few mm taken off the crank side. It barely fits. I'm using the hardest urethane mounts from innovative so it hasn't rubbed the frame rail yet.
They all look to be 60mm. I couldn't get right up to my D16 pulley, but the H23A and B18 pulleys I measured were 60mm. You have to get a good 25% undersize before voltage gets low at a normal idle.
My B18 alternator pulley came in at 2 and 3/8".
That is because you are usisng the alt relocator, or your pulley doesn't need it, or anything else?
Another question:
If you use the alt relocator it goes where the A/C compressor should, right?
What if I want to have A/C? Will be able to left alt and A/C where they should be from factory without having problems with belt or pulleys hitting the frame?
I am doing a 93 del Sol, EG, which have very similar (if not the same) engine bay of 92-95 civics and 94-01 integras. Want to have A/C. Please advice.
P.D.
Live in PR (caribbean) A/C is used all time of the year.
P.D.
Another question:
P.D.
P.D.
music462
Sep 1, 2008 11:19 AM
