MAP sensor
Old Sep 16, 2014 | 07:16 PM
Turbolude96's Avatar
Default MAP sensor
I've got a possibly stupid question about the map sensor on my 96 prelude h22a1.
I pulled the motor and am currently getting it ready to install so I'm hooking up the wire harness before I drop the motor back in.
I've seemed to have located where all the connectors go back but I can't find my MAP sensor plug anywhere!
I looked all over and can't find any info on what harness the plug is on, does anyone know what plugs it is by and how I can find it?
I know there's 3 wires to it and I know it's a circle connecter with the release tab at the 12'oclock position and one alignment key at the 9'oclock position. I've compared that to all the connectors I see and no luck
Old Sep 16, 2014 | 09:43 PM
joytjuhhhh's Avatar
Default Re: MAP sensor
Hey i had the same.with my obd1 b16a2 delsol.
Before removing the engine there was a map plug.and then i put the engine into a civic eg4.and the plug was gone.(using a esi interieur interieur loom and the delsol engine loom )did a lot of reseach and thougt i was going crazy.but on some cars it seams that the map plug came straight out the ecu thru the firewall to the map sens.
Or in some cars with abs the map plug is wired tru the abs loom.
Now i wired it straigt from the shocker tower to the map sens
attica
12
Aug 20, 2009 08:43 AM
mr.ed605
Mar 8, 2009 12:33 PM
RudeLude95
Apr 14, 2005 11:30 AM
fre$h
Jan 10, 2005 02:11 PM
