1st gear bounce
Old Sep 16, 2014 | 07:14 PM
FlipsR6's Avatar
Default 1st gear bounce
Ive looked around and havent found a thread on this. When i give it gas(clutch already in) in 1st gear or i let off the gas then try to keep a steady rpm below about 3k it will "bounce" when i say bounce its like a motorcycle with a loose chain, when the chain goes loose the engine revs higher and pulls the chain tight then the bike jerks and the process continues. I had a bad passenger axle and i replaced it hoping it was just slack in the axle but that didnt do it. Id hate to think i ts the motor mounts since their almost brand new... Anyone have any thoughts? 94 civic si hatch with b20vtec swap, aem intake and fuel rail, skunk 2 throttle body etc etc oh and ys1 big spline tranny
Old Sep 16, 2014 | 07:47 PM
tony_2018's Avatar
Fish Twig
Default Re: 1st gear bounce
It jerks.......you need to check your tps sensor.
Old Sep 17, 2014 | 12:07 AM
NotARaCist's Avatar
I never narc'd on nobody!
And what clutch and flywheel are you using?
Old Sep 18, 2014 | 10:51 PM
Eg5ir1's Avatar
X2 mine had a dead spot at around 2k rpm ,when I hit 2k my car jumped like it got bit in the ***, anything before or after it ran perfectly fine.
Old Sep 27, 2014 | 06:50 PM
FlipsR6's Avatar
wow totally forgot about this post lol, i fixed the problem. It was the throttle body stop screw was missing and was doing wierd things to my tps making it stop fuel then add fuel and bouncing me around. Thanks for your input all
Xpertgamin
Nov 27, 2017 07:15 PM
jdmchickx
Dec 3, 2011 04:09 PM
dazelman
May 27, 2010 11:34 AM
h22pwr
May 25, 2005 09:50 AM
1hotintegra
Oct 14, 2002 11:26 PM
