H22a euro R obd1 or PCD ??
Old Sep 16, 2014 | 05:42 PM
mugen94's Avatar
Default H22a euro R obd1 or PCD ??
H22a euro R in EK
what should I run and why ? I have both ECU p28 and the PCD.
Old Sep 16, 2014 | 07:25 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: H22a euro R obd1 or PCD ??
Unless it's modified, I'd suggest running the OEM ECU and wiring in the IAB if you're using that manifold
If you aren't using the IAB manifold, a chipped P28 with a proper tune will run great. Alternatively you can install the IAB circuit in the P28 and wire in a relay.
But an H series engine will never run right on a basemapped P28, especially if it's modified, so it needs to be tuned if that's the route you choose.
borrego_cd5
Apr 27, 2011 10:00 PM
732xghost
Jul 26, 2007 03:03 PM
tr0n9h
12
Oct 13, 2005 06:16 AM
abeaujuin
Jul 27, 2004 09:01 AM
