installing springs
Old Nov 1, 2002 | 06:01 AM
1hotintegra's Avatar
Default installing springs
is puttin in springs easy... i've never done it before but im pretty good with doin stuff myself... i know i need a spring compressor... anything i really need to know.. i got totiko springs and struts for 400$.. and i dont wana wast money on installing them...thanks
Old Nov 1, 2002 | 06:36 AM
The_Oz's Avatar
Default Re: installing springs (1hotintegra)
Having an air impact wrench helps tremendously. If not, be sure you have a Johnny Bar. Be prepared to use a torch to take out siezed bolts, and replace them. Also, it is a good idea to coat the bolt threads with anti-sieze.
Good luck,
Oz
Old Nov 1, 2002 | 06:53 AM
Default Re: installing springs (The_Oz)
i just had eibach prokit put in about 6months ago maybe.. would the bolts still be seized???... what is a johnny bar??
Old Nov 1, 2002 | 11:04 AM
JSTOCK's Avatar
If anything is seized up......PB Blaster will become your new best friend.
It's really a simple install. It is a good day project.
Old Nov 1, 2002 | 11:40 AM
SoulSurfer's Avatar
Default Re: installing springs (jstock107)
It's an easy project but like they've said, bolts seize. The most common problem is the real lower control arm seizes and the head breaks off.
Old Nov 1, 2002 | 01:09 PM
ryaneg6's Avatar
Default Re: installing springs (LSDelSol)
this happend with my cx before. we had the hardest time, but ended up using a torch to cut off the whole lower control arm and finding another pair at the junk yard. this was before i got a air compressor and a 1/2" snap on impact wrench.
Old Nov 1, 2002 | 02:46 PM
performula's Avatar
It took me about four three hours to one side the first time I intalled my front shocks.
Cutting collar, forgot to put top washers under the shock tower, etc. Now it takes 30 minutes for each front side. I know because I've been under there three times. The first time is the hardest, then cake afterwards.
Old Nov 1, 2002 | 02:49 PM
performula's Avatar
Default Re: installing springs (performula)
Leave your hood up when you lower your car afterwards! The rears are OK, because nothing is over top of the rear towers.
Leave the hood up and push up and down for about one minute. Even if you know you did everything right. Just is case. Don't want to dent your hood, or damage your CF hood.
Old Nov 1, 2002 | 03:01 PM
Rydaddy's Avatar
I went down and rented a spring compressor from Kragen today, but i cant fit the damn things in between the coils of the springs. Do i need to get a special one for imports? Since the compressor didnt work, I decided to remove the nut at the top of the strut with a jack under the lower control arm in the front, and the **** got wedged in there. Turns out I BENT the ******* damper fork and now the whole assembly is stuck in there. HELP ANYONE>!>!
Old Nov 1, 2002 | 03:27 PM
ismkv8s's Avatar
its easy if you are mechanically inclined, 30min to an hour if bolts are hard!On a scale of 1-10 its a 1.
Old Nov 1, 2002 | 04:24 PM
performula's Avatar
Default Re: installing springs (Rydaddy)
What now? How the hell did you ben the fork?
Old Nov 1, 2002 | 04:44 PM
Rydaddy's Avatar
What now? LoL. I think the fork bent when I was trying to hammer out the damper fork bolt. I was hammering it because the bolt was wedged in there from the force of the spring trying to un-compress(?). Can i bend it back, or do i need a new one?
Old Nov 1, 2002 | 06:13 PM
b00stn's Avatar
I had the same problem get the spring compressor to work. It wouldnt fit between the spring coils. You shouldnt be trying to take the spring off until you have the entire spring/strut assemble pulled off the car though. There are the three upped bolt that you get to from inside the engine bay. Then the lower bolt holding the fork that is holding the strut. I had to have my dad stand on the rotor to push it down while I beat that bolt out. It was kinda a PITA but not to bad. Once you get that whole assemble out, you can work on compressing the spring.
[Modified by b00stn, 7:14 PM 11/1/2002]
Old Nov 1, 2002 | 06:15 PM
b00stn's Avatar
Default Re: installing springs (b00stn)
Here try this link. Should help out.
http://www.bseries.net/html/garage/spring.php
teggsr925
May 26, 2006 11:24 AM
jay73
Aug 24, 2004 05:02 PM
1hotintegra
Nov 5, 2002 09:19 AM
puhlode
Mar 14, 2002 05:16 PM
AJTEG
Jun 21, 2001 09:38 PM
