Window problem
Mine did this also and it was the rubber seals that are on the sides. They get dirt and crap in them which lead to friction.
Clean them out and use some sort of silicone lube and see how that werks for ya.
Cables? I'm pretty sure our window regulators do not use cables.
OP, you have the window out and the regulator isn't going up then the problem is either your regulator *and or guides* or the motor. Not much else to it.
Since it rolls down that means the wiring is ok. If a wire to it was broke it wouldn't go down either.
hondaEg_808
Nov 30, 2010 12:35 AM
dingobat
Oct 9, 2008 09:56 AM
