s200 or s300 for my lsv turbo? which is better?
Old Sep 15, 2014 | 01:03 PM
Ortizalex714's Avatar
Default s200 or s300 for my lsv turbo? which is better?
I need I'm boosting my lsv high compression.
Old Sep 15, 2014 | 01:58 PM
Lazysk8r2's Avatar
Default Re: s200 or s300 for my lsv turbo? which is better?
Go with S300, S200 is discontinued.
Old Sep 15, 2014 | 04:48 PM
Ok thx
Old Sep 15, 2014 | 05:59 PM
jdm_ek_noob's Avatar
S200 is cheaper and should work fine; however, they arent easy to find. Also, boost option came separate with the s200, and a tuner will need that for a proper tune. If you were to get an s200, then you would have to call Hondata (or connect it to a PC and run the software for it) and verify that it has boost option. These units are discontinued so you would NOT be able to buy boost option if the unit does not come with it. The s300 is pricy, but it comes with more features than the s200 and will also work perfect for your setup. Go with the s300 unless you know for sure you can get a good s200.
95dxsir2
Aug 25, 2007 02:37 PM
95dxsir2
Aug 25, 2007 02:33 PM
Prudz_lude
May 29, 2007 07:01 AM
PaJeeZy
Mar 20, 2007 11:14 PM
es four
Mar 31, 2003 03:38 PM
