stock vs aftermarket keepers/locks
picked up some portflow valve springs and ti retainers but no keepers. would it be safe to run stock keepers on ti retainers or should I just go with supertech or so.
I think at this point most VTEC heads have well over 100k miles on them. Would be a good idea to replace what you can while it's off the block. I have used the Supertech keepers from THMotorsports. They are roughly $25.00.
I also use stick keepers no issues but I check them over for excessive wear.
Are those ssuper tech the same angle as oem I think 7 degrees so they can be used with oem retainers too
While on the topic,what to you think of this kit ? http://www.ebay.com/itm/SUPERTECH-VALVE-LOCKS-KEEPERS-VALVE-SEALS-GSR-B16-GSR-B18C1-B18C5-K20A-Honda-/300953542513?pt=Motors_Car_Truck_Parts_Accessories&hash=item46123a9f71&vxp=mtrIs it worth the money?
While on the topic,what to you think of this kit ? Supertech Valve Locks Keepers Valve Seals GSR B16 GSR B18C1 B18C5 K20A Honda | eBay
champwhiteEG6
26
Sep 26, 2007 02:09 PM
bigsubs
Oct 15, 2006 07:20 AM
xci_ed6
Oct 14, 2003 01:27 PM
