Parking Brake Light
Old Sep 14, 2014 | 03:29 PM
2010coupe's Avatar
Default Parking Brake Light
So I need some help, What seemed to me would be a pretty easy fix is now something I cant figure out (Probably easy and I'm overlooking it).
I am driving down the street and I hit a bump in the road that causes me to bottom out pretty hard. The only thing I noticed is the parking brake light flickered on and off and then stayed on.
I jacked up the car and checked underneath for any damage and thank god there's none, small scrape on the bottom brace and the exhaust.
Back to the problem, I pulled the ctr console off thinking it was a grounding issue, corroded or dirty. Cleaned off the sensor-pulled off the parking brake lever and put a steel brush to all of it. Light is still on-checked for continuity and it looks good-now I don't know what to do.
the light is still on and it is bugging the S*#! out of me!!!
Any thoughts would be greatly appreciated.
Oh, sorry-94 Accord Ex (F22B1)-manual transmission.
Old Sep 14, 2014 | 04:16 PM
holmesnmanny's Avatar
Check your brake fluid level.
Old Sep 14, 2014 | 04:39 PM
2010coupe's Avatar
Default Re: Parking Brake Light
Brake fluid is fine....double checked just to be sure
It's the parking brake light that's on (mechanical) the one indicating if it is in the up or down position.
Thx for the reply....any other thoughts?
Old Sep 14, 2014 | 05:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The BRAKE indicator lamp can be caused by either the brake fluid level switch or the parking brake switch.
The issue can be related to the brake fluid level switch; the switch may be stuck closed when it should be open (if the fluid level is okay).
Old Sep 14, 2014 | 06:25 PM
2010coupe's Avatar
Thanks to all for the help-so the brake fluid did look fine, I went back and topped it off a bit more though just to be sure, and sure enough the light turned off. Curious now why the level would have been lower. I'll keep an eye out for leaks- thanks again to both of you for your help.
Old Sep 14, 2014 | 06:28 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The brake fluid reservoir level will drop as the brake pads wear down. So, it doesn't necessarily mean there is a leak.
Old Sep 15, 2014 | 12:03 AM
I really need to pad my profile pic so noobs start listening to what i say.
Old Sep 15, 2014 | 06:31 AM
2010coupe's Avatar
Hey..., slow down cowboy.
I took your advice and said thank you.
I bow down in appreciation.
The key to learning is understanding the problem
Thanks again for your help.
BukThout
Apr 10, 2007 07:44 PM
intech
Nov 17, 2005 02:44 PM
civicboisi
Mar 8, 2003 06:45 AM
Slow
Oct 29, 2002 03:38 PM
hybridbmw
Feb 19, 2002 10:38 AM
