changed ignitor and coil now car wont start
Old Sep 13, 2014 | 12:16 PM
Civic Racer X 7's Avatar
Default changed ignitor and coil now car wont start
I changed out the ICM and the coil this morning and the car wouldnt start
then I put the ones in that were working and it wont start
I have power to the coil
whats going on?
I thought I might have accidentally got the dizzy 180 degrees wrong even tho I paid attention to it
it doesnt seem to go in the other way
new ngk iridium and ngk wires
Old Sep 13, 2014 | 12:22 PM
Norlael's Avatar
Default Re: changed ignitor and coil now car wont start
did you remove the battery cable from the post when you made the repairs? check 80 amp and 50 amp fuses in U/H box and acg underdash
Old Sep 13, 2014 | 12:24 PM
tony_2018's Avatar
Fish Twig
Is it cranking but not running?
What's an acg?
Old Sep 13, 2014 | 12:26 PM
I paid close attention when changing the icm
The test light lights up or both the neg and pos side of the coil
That's odd
Yes cranking but not running
Old Sep 13, 2014 | 12:27 PM
Norlael's Avatar
oops acg 15 amp fuse under dash thnk its no 1 or 3 but says acg on the fuse label thingy. usually blows when ignition or alt components ground out
Old Sep 13, 2014 | 12:32 PM
tony_2018's Avatar
Fish Twig
Double check the wiring on the ignitor.
Old Sep 13, 2014 | 12:37 PM
See anything wrong?
Old Sep 13, 2014 | 12:53 PM
Norlael's Avatar
black and yellow needs to go to where green is plugged in green goes on the side
Old Sep 13, 2014 | 12:54 PM
All fuses under dash are good
And under hood too
Old Sep 13, 2014 | 12:59 PM
Norlael's Avatar
here
Reps for norlael
You are the man
cs1985
Mar 10, 2008 04:17 PM
ge_itr
Mar 29, 2007 07:29 PM
slow91crx
Apr 27, 2005 06:53 AM
wanttorace
Oct 8, 2002 06:42 PM
wanttorace
Oct 5, 2002 10:31 AM
