Engine vibes after I changed my motor mount
Old Sep 13, 2014 | 07:21 AM
Em1-2000's Avatar
Default Engine vibes after I changed my motor mount
Last night I changed my motor mount on my 2000 si , the top driver side. I had my uncle helping me and he jacked the car up from the crank pulley and now every time I give it has it vibrates ...
So I don't know if my other mounts are bad or if I just completely ruined my car by him doing this 😕
Old Sep 13, 2014 | 09:16 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Engine vibes after I changed my motor mount
Recheck the bolts but you should never jack it up from the pulley. When you look at the pulley when running does it seem out of balance?
Old Sep 13, 2014 | 11:32 AM
jdmcivicsi187's Avatar
Ya that wasnt a very smart move on your relatives parts. But like hondapartshero said check the pulley and inspect the other mounts
Old Sep 14, 2014 | 04:22 AM
underrated's Avatar
Try loosen all the mounts and re-tighten according to FSM.
Old Sep 14, 2014 | 04:48 AM
TanEJ1's Avatar
Honda Engines are Strong ,built simple.... Jacking it up from the pulley shouldn't kill the motor. As for vibrations this is normal with any new mount... I installed All new hasport extreme mounts on my 92 si hatch, with a d16z6 and the dash never stopped having vibrations. This will be the same with any new mount....
Old Sep 14, 2014 | 08:06 PM
Em1-2000's Avatar
I checked the pulley and there was no wobble, doesn't seem out of balance . My rear mount is really bad, today I changed the passenger and it helped alot
Old Sep 15, 2014 | 02:28 AM
underrated's Avatar
Are you using an FSM? Is shows the order the mounts are supposed to be tightened down. There's a note that says you will get vibration if not tightened in sequence.
Em1-2000
Sep 14, 2014 01:34 PM
Hondacivic90ed
Aug 11, 2012 05:41 PM
tag0617
Apr 12, 2009 06:13 PM
white_panther
Dec 8, 2006 04:47 PM
Boosted2K
Jan 18, 2005 08:10 AM
