Setting up inputs for logging EMAP and Fuel pres on Neptune.
Old Sep 11, 2014 | 07:12 PM
a1320honda's Avatar
Default Setting up inputs for logging EMAP and Fuel pres on Neptune.
I want to setup EMAP using B6 input and know i have to remove R2 and R3 resistors. And for fuel pressure i wanna use D12 EGR lift input but dont know if i need to modify any part of the ECU to use the D12. Any info would be appreciated.
Old Sep 12, 2014 | 08:03 AM
ef92b's Avatar
Default Re: Setting up inputs for logging EMAP and Fuel pres on Neptune.
You should have C42 present. .1uF cap.
Old Sep 12, 2014 | 08:45 AM
a1320honda's Avatar
So C42 should be present in order to make D12 work?
Old Sep 12, 2014 | 09:56 AM
ef92b's Avatar
So far, it's what I've done on two P28 ecu's with Neptune/Demon and have been working fine for the past two years till to date
Edit: Link added below.
http://wikitest.pgmfi.org/twiki/bin/...hAsAnEgtSensor
Old Sep 12, 2014 | 01:32 PM
HRTuning's Avatar
If you're just using it for logging purposes you have the Demon analog inputs as well.
Old Sep 12, 2014 | 06:43 PM
a1320honda's Avatar
Where can i find the info on wiring these in?
Old Sep 13, 2014 | 05:55 AM
HRTuning's Avatar
If you have a Demon 1, RTP Tutorial Videos under support on the web or in software help.
If you have a Demon 2, it's the same thing, but the terminals are pre-installed.
Luisrivera2510
Feb 17, 2011 05:24 PM
b20beast83
Jun 19, 2010 07:42 AM
C_H_A_D
Welding / Fabrication
Apr 6, 2007 07:23 PM
soon2boost
Nov 30, 2004 04:59 PM
Greyout
Feb 3, 2004 12:24 PM
