Electrical problem 94 accord
Old Sep 11, 2014 | 05:25 PM
onunezp's Avatar
Default Electrical problem 94 accord
Good night fellas,
i have ANOTHER question for you,
4 days ago my car's battery indicator was on, and the car would die, i changed the diodes plate in the alt, now i have another problem, the light is gone, but here is the problem,
the car starts fine, i can drive it for like 10 minutes with no issues, but after a while, my tach and speedo goes to zero, then the wipers and lights go down, the car even dies, no power windows, no acceleration, dead,
but if the car sits for 15 minutes, starts back up,
runs, and everything works, dim lights and slow power windows, but it runs,
and the cycle starts again, driving a few minutes and same story.,
what do you think might be causing this problem?
is very dangerous, 20 minutes ago it died in a bad area of my city, and i was with my child and wife,
thank you
Old Sep 11, 2014 | 05:56 PM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Electrical problem 94 accord
Verify with an accurate volt meter that Your cars charging system is >14.1 volts at idle with the lights on. If not, it has to be corrected. Many weird thing can happen when the ECU gets lower than 10v like relay shutter and fuel pump issues too.
Dim lights and slow windows are a real indicator of low voltage.
good luck
Old Sep 14, 2014 | 10:13 AM
onunezp's Avatar
good luck
thanks, found what the issue was, somehow, my alternator was disconnected from the three pin connector, it didnt have the o-ring.
made the tests you told me, and everything is ok, thanks a lot!!
guyver13
Audio / Security / Video
Oct 21, 2012 12:12 AM
dasjestyr@gmail.com
Feb 23, 2009 11:29 AM
j0keefe21
Jan 28, 2009 03:56 PM
rdiggidy
Aug 17, 2004 05:16 PM
