89 si fuel pump mystery
So I'm sadly selling my 89 hatch with d15b VTEC and obd1 conversion, we had it firing up roughly the other day then I cleaned all grounds drained the tank put new gas in and tried again, now the fuel pump isn't kicking on and the spark seems weak, I double checked the ground on the thermostat/water pump thingy, cleaned it and reattached it no change. If there isnt enough gas in the tank will it not kick on? Are there more grounds I could check? The pump has power at the plug also. Again there is spark but it does seem kinda weak the dizzy is pretty new so I don't think that's it either, any ideas?
Steenracing
11
Oct 7, 2014 08:55 AM
D'PEXi
Apr 7, 2009 07:41 PM
alky350
May 1, 2003 06:18 AM
