D16y8 swap to y7 help!
hey there,
My friend had a y8 in her 98 Honda civic si but it blew a head gasket and warped the head and block so she picked up a y7 and got it put in but put the y8 manifold on, when trying to run the y7 ecu it idles really low and is throwing CEL code 14 which I believe (from research) is IACV, now I know non-vtec cars have a 3 plug iac but her mani has a 2 plug do I repin the ecu side or do I find a non-vtec iac and plug and wire it up, also do I need to change any of the distributor wiring I was told y7 dizzys use different plugs than the y8s
thank you for you're time
jayjay0718
Jul 29, 2006 08:01 PM
