1992 Honda Accord engine vibrate and puff sound at 1700-2000 RPM
Old Sep 10, 2014 | 06:06 AM
knaup109's Avatar
Default 1992 Honda Accord engine vibrate and puff sound at 1700-2000 RPM
Hello,
Recently, the engine vibrate and puff sound at 1700-2000 RPM. Once I exceed the 2000 RPM, the engine run smooth.
I did some research, so far I lean toward exhaust resonator. I am not sure if I have a exhaust resonator.
Thanks in advance
Old Sep 10, 2014 | 09:48 AM
rwfxp1's Avatar
Default Re: 1992 Honda Accord engine vibrate and puff sound at 1700-2000 RPM
To me, it sounds like an ignition problem.
Have you changed your timing belt recently?
If not, check your spark plugs, spark plug wires, and distributor cap.
Make sure no oil is leaking on the spark plugs.
Old Sep 12, 2014 | 11:36 AM
Lost Again's Avatar
Then you might also check into/read about clogged egr ports. Hard to call but at that rpm that is where clogged ports can give you "issues" close to what you are describing.
Jovyson1
Sep 7, 2018 05:49 PM
jdhatton1
Aug 31, 2015 08:22 PM
jeffv
Dec 27, 2012 10:03 AM
billybob8469
Aug 22, 2012 09:01 AM
rollinhonda3
Jul 25, 2011 03:30 PM
