Lock cylinder changed, key doesn't rotate completely
Old Sep 9, 2014 | 07:00 PM
Jeff the wrench's Avatar
Default Lock cylinder changed, key doesn't rotate completely
Changed lock cylinder, on a 91 accord. Now key doesn't turn to start position. Removed a micro switch with a lever in the housing, now key turns fully. What is this switch? It has two wires to it, both hot till switch is closed. Is this the switch to get gear lever out of park? Installed switch several times, either the key won't come out or won't go to start position. Help jeff
Old Sep 9, 2014 | 09:36 PM
holmesnmanny's Avatar
Default Re: Lock cylinder changed, key doesn't rotate completely
Take some really detailed and close up pics and let us see what's going on.
fazalabbas
Jan 5, 2019 10:36 PM
Jeff the wrench
Sep 9, 2014 06:55 PM
Moog_enep3
Nov 6, 2013 11:03 AM
GoldCoin
Oct 24, 2007 12:09 AM
oMek
Oct 29, 2003 04:16 PM
