V-band adapter
I am looking for either a 2.5 to 2.75 or 3.0 to 2.75 v-band adapter?I have looked around with no luck.I am under the impression this would be simple to do the smaller of the two flanges would just have to be made a bit taller to seal inside the clamp with the larger flange right?I have never used v-bands and I am just trying to figure out the easiest way to get a 70mm TB to a 2.5 inlet precision intercooler.Any help would be greatly appreciated.Thanks
interesting concept, but not worth the headache. just use the same size v-band on each end, but use a conical reducer on the tube to attach to the v-band. they are super common and can be found at really any metal supplier
Forced Performance Turbochargers: FP 2.5" - 3" V-band Clamp & Transition Flange Set
this should work goes from 3" down to 2.5 inch, you could just cut it were it comes to 2.75"
