How to remove door sill trim & left kick panel
I am replacing my inner fuse box but I run into trouble because I don't know how to remove my left door sill trim & left kick plate.Did anyone done this before?Please help... Btw my car is 2004 Accord sedan.
Steps are part of these instructions for installing the Honda accessory security system:
http://techinfo.honda.com/rjanisis/pubs/AI/AII25712.pdf
Re-check all the harness connectors, fuses, and relays to ensure they are firmly connected and there no blown fuses. If you don't find the issue there, then check for blown fuses in the under-hood fuse box.
Take a look at the Under-hood Fuse No. 23 Multi-fuse (50A/50A) to make sure it is not blown.
http://parts.rosenthalacura.com/prod...52dA11%29.html
slo95cx
Aug 7, 2004 08:47 AM
