Looks like another TPS question
Hi all
This is my first post. I have read loads on the TPS but not sure if I can find the answer I need. I have a 2002 CRV with the codes P0122 (TPS) and P1298 (ELD). Replaced the Throttle body with a recon one but still have he MIL on. no matter how many times I disconnect the battery or try to do the relearn process it always comes back on.
As the unit is recon I am thinking is the TPS not set up correctly.
My question is do I have the move the TPS until I get the correct voltage required. I can see people have done this on the older models of the CRV but it that also relevant to the 2002 model.
I have ordered a new ELD which will be here on Monday and that looks fairly straight forward to fit without dismantling the fuse box.....phew.
Thanks for your help
rice4life
Jul 27, 2004 06:31 AM
