speed sensor issue, b series
Old Sep 4, 2014 | 06:53 PM
SpeedOFsmell's Avatar
Default speed sensor issue, b series
I have a turbo b20/b16 transmission obd0 in an ef hatchback. Ive been chasing overheating issues and flickering tach problems, and I finally discovered the cause when my speedo cable happened to shake out of its socket on the transmission today. As soon as it came out of its hole, my tach stopped bouncing, my coolant temp dropped to normal, and my lights stopped flickering with my turn signals. Im so relieved, but need some pointers. I dont understand how a mechanical speedometer can cause these electrical issues. Its cable driven! Am I missing something?
Old Sep 4, 2014 | 07:10 PM
Default Re: speed sensor issue, b series
If I jiggle the speedo cable at the transmission the gauges go nuts. Wtf.
Old Sep 4, 2014 | 07:39 PM
n/a2boost's Avatar
Check the thermostat ground and all other grounds.
Old Sep 4, 2014 | 07:43 PM
I did that before I even knew this was the problem. I even added 3 extra grounds.
Old Sep 4, 2014 | 08:05 PM
I'm starting to think that maybe there is a faulty ground related to the cluster or something, and it makes intermittent ground through the speed cable, and as I jiggle it, I break and reconnect that ground. Odd.
Old Sep 5, 2014 | 11:05 AM
m4xwellmurd3r's Avatar
Actually I found on my da (and all da integras that ive worked on) ground the cluster through the speedo cable. Its bizzare I know but pulling the cable out causes the cluster to freak out in strange ways. Hook it back up and alls well again
Old Sep 5, 2014 | 11:14 AM
edvas1's Avatar
Weird. My speeds mechanical sender in the tyranny is bad in my ef n my tach cluster is fine.
Old Sep 5, 2014 | 09:42 PM
VeeSykkz's Avatar
On my prelude the speed sensor assembly was only held down by one bolt on an arm sticking off the module. The arm broke off and the gear into the tranny wouldnt hold in. Dunno if civics are the same way, never owned one.
Old Sep 6, 2014 | 12:08 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Huh. Yea it sounds like its grounded through the cable, does it show it in DA teg helms manual schematics?
Old Sep 9, 2014 | 12:12 AM
It doesnt show that its supposed to ground through the cable. The cluster has 2 harness grounding points. One by the windshield washer bottle, and another by the fusebox. Theyre those bulk wire things that bolt onto the body. And as far as I cam remember, g301 (by the washer bottle) isnt bolted on my car and just hangs out. But I could be wrong.
Anyways it sounds like a missing ground causes the issue. Ill bet if you made a ground going from the cluster main ground to the body it would stop freaking out when the cable slips out
88_hatch_ls
Sep 4, 2013 05:47 AM
AllMotorLudeSi
Jun 9, 2012 06:24 PM
TMC_EF
Jul 16, 2007 10:37 PM
b20 crx
Oct 10, 2005 12:27 PM
turbob16ef
Oct 9, 2005 02:02 PM
