Leaking gas
Old Sep 4, 2014 | 08:29 AM
vtrp2008's Avatar
Default Leaking gas
94 civic ex coupe stock everything
I started getting a gas smell towards the rear of the car. So I jacked it up and there's a small puddle of gas under where these to lines meet. Am I able to just cut the fittings off and put a rubber hose to connect them?
Old Sep 4, 2014 | 08:32 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Leaking gas
I'm not positive but I do believe the gasoline will slowly eat the rubber away.
I think this is why all fuel lines are metal piping with metal crush washers etc for joints.
I believe your proposed solution is asking for even more troubles relatively quickly.
Old Sep 4, 2014 | 08:34 AM
vtrp2008's Avatar
Gonna have to order new lines then... I called honda and the guy had no clue what I was talking about when I said the line coming off the fuel pump, down under the car and it meets another line at a bracket
Old Sep 4, 2014 | 08:35 AM
vtrp2008's Avatar
Driving it probably isn't a good idea I suppose
Old Sep 4, 2014 | 08:42 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
you can get fuel injection hose, which is rated for the pressures, and the corn in todays gas, but you need to make sure it's stamped that it is, directly on the hose. Some places will try to sell you vacuum line as fuel line. I dont like rubber hose, but with the proper clamps and hose, it should be ok for a little while, until you can get the right hose
Old Sep 4, 2014 | 08:45 AM
you need to use fuel injection hose clamps too, they should have them at most auto parts stores. if you can find them use Oetiker ear clamps
Old Sep 4, 2014 | 08:53 AM
vtrp2008's Avatar
Ok thank you, I was getting ready to go for a drive and I was like wtf doe is smell like gas for...can only imagine how long it's been leaking..
Old Sep 4, 2014 | 08:55 AM
http://www.zoro.com/i/G3201432/?utm_...FaTm7Aodo1cA2Q
tolowhb
16
Jul 24, 2020 07:37 AM
vulch
May 8, 2015 08:09 AM
SlowazzGSR
Honda Motorcycles
Apr 3, 2010 06:50 PM
Acidcrakker
Nov 12, 2007 06:50 PM
whiteturbohatch
Aug 16, 2005 01:01 PM
