b18c smoke issue
Old Sep 4, 2014 | 07:39 AM
bad23591's Avatar
Default b18c smoke issue
Having a little problem. I have done a full b18c swap in a 93 ej. Bought full swap from hmotoronline and been very reliable. It is pretty much my track car and every other day I will drive it to work. My issue is when I take a hard turns on the track it smokes pretty bad. Running 275/35 Hoosier r6 so it has some serious grip in the corner. First noticed it at nccar in North Caroline. Taking the long sweeping turn, was going clockwise so it was a long left turn that sweeps almost 360°. I know its burning the oil cause after about 3 lap I'm about 1 to 1.5 quarts low and quites smoking. No leaks. Drove it to work for awhile to make valve seals or rings bad. Burns about a quart between oil changes 3000 miles. Doesn't smoke when I fire it up in the morning. Small puff of black smoke if I down shift and romp on it but no blue smoke. I'm am stumped. No oil in intake either where valve cover port connects to intake.
Old Sep 4, 2014 | 08:37 AM
EpHatchy's Avatar
Default Re: b18c smoke issue
think this thread might be better in the autocross sub-forum. what do you have for a catch can ventilation system?
Old Sep 4, 2014 | 09:24 AM
bad23591's Avatar
Stock setup. Thought about running a catch can.Think breather box needs to be cleaned.
Old Sep 6, 2014 | 12:22 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
bump, dont have any advice, but im curious to see what the prob is. good luck!
bad23591
17
Sep 19, 2014 08:21 PM
carlosd68
Apr 3, 2014 08:47 PM
codyb13
Jun 16, 2005 08:47 AM
js96ek
17
May 17, 2005 12:18 PM
B18Ccivic
Feb 2, 2003 05:25 PM
