help! vx chassis harness with DX engine
I have a vx chassis/dash harness and a DX engine bay harness hooked to a D15b7 and need to know exactly what to do to hook it up right.which wires to re-pin because something is messed up and car won't shut off in reverse and if the car is off and I it it in reverse the dash lights come on and something by the driver fuse box ticks clicks or arcs. So I'm loooost haha
Other then extra wires for oil pressure/vtec/EGR and on some cars (02 sensor) there should be no difference and should not affect you in way you describe it.
1) check your ground wires
2) make sure the wires are connected fully and fuse box screws are tight
3)repin 02 sensor if 5 wire version
What ECU are you running? p07 or p06 (dx)
V-SPEC 1
21
Dec 2, 2004 09:01 PM
