Ruined my b18c
Long story short.
I called HMO and other places to see if they have a short block. No one carries one. A ITR crankshaft runs roughly around $1000. And a long block is roughly $2500.
Any ideas where I can get a legit, and by legit I mean from people with good history that won't **** me over, short block?
Or...
get an b18b for smogging purposes (California)
h2b
b18c (sir or type r) semi/fully built
- Came back from a 9 month deployment.
- Drove my caR, thats been stored for 11 months, didn't drive it too hard.
- Drove my girlfriend to the airport, heard rattling in the engine bay pulled over and found my P/S belt ripped and the tensioner pulley offset. and stupid of me, i still drove it for another ~50 miles, made it back home though.
- Found that the tensioner pulley pin fell out, gouged my tensioner pulley and chipped the socket where the pin would go to keep both components aligned.
Or...
h2b
I know that I'm missing something.
You don't have power steering, because the PS belt broke.
Tensioners get old and can be replaced.
What don't I understand?
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I think he's saying the keyway on the crank got damaged from the pin being misaligned, so now you can't put the pin back in, crank snout is ruined
I wonder if there is a machine shop that can fix that? it's not like it's the journals or anything, keyway can always be welded and recut, I've heard of that being done on expensive or rare cranks, there might be a possibility of lining up the pulley and drilling and tapping the crank snout for bolts,
I heard good things about ERL Performance short blocks.
http://www.erlperformance.com/honda-...rl-superdeck-i
I would never "fix"that. The short block or rebuild with a new crank is the way to go. I wouldn't feel too bad about driving it, by the time you heard a problem the damage was already too far. Even a little crank damage and a new balancer they always come loose and will haunt you for life from my experiences. I've welded them on a beater before though with "success" lol.
Have a machine shop machine a new key-way 180* around the crank snout. Then have the same keyway machined 180* into a replacement pulley. As long as both are exactly 180* off, you shouldn't have any trouble timing the engine.
Have you tried any salvage yards? They're usually reputable and will usually give you a 7-30 day warranty.
I've never had any trouble with anybody here: http://www.car-part.com/ (nationwide salvage listings)
sorry to hear about that...i was confused at first too because just missing a p/s belt isnt the end of the world or the engine. it just means at low speeds youre going to be exercising your arms a LOT more..
you "could" use it as an excuse to make it faster...but ill tell you from experience that can cause other issues lol..
In most places in the states, people charge an arm and a leg for ITR parts cause its "JDM yo!" I want to get another crankshaft but I dont wanna fork over $1000 cause if I end up doing that I might as well build a better motor.
I never thought about that, thanks lol! that could save me a few hundred dollars for other things =D
The problem with a new keyway is everyone I have seen do that has marked up the crank making the crank mating surface smaller. A new pulley will be a bit loose on the crank and the crank bolt will never stay tight.
yeah... that was the plan.. lmao. I have a ls-vtec turbo set up from my brothers old car but im kind of not digging the B series anymore unless its N/A with ITBs. lol I love the sound. but if you look closer at picture 3 you can see the chip/nick in the snout. i didnt mention that in the pictures above. But i should to stop the confusion.
BTW: It's also only $3k for a brand new US C5 short block. You could part out your old one and re-coupe some cost: http://www.oemacuraparts.com/auto-pa...sion-assy-scat
No you would cut a new key way on the opposite side of the crank. No need to re-grind anything. Just leave the chipped side alone.
But, welcome back
