trans swap help
Old Sep 2, 2014 | 04:27 AM
killerb7888's Avatar
Default trans swap help
I have a 1990 CRX Si, however, that is irrelevant for this question.
I have a 1994 D15Z1 engine that I'm trying to install a CRX HF trans on however my HF trans has 21 splines and the D15Z1 clutch has 20.
Is there anyway I can swap the input shafts on these two transmissions?
If not will P/N:HCD005U solve my problems?
If not, is there any vendor who sells the 21 spline coupler that I can have pressed into the existing clutch?
I'm really not trying to spend $100 on a new clutch kit when there's nothing wrong with my clutch, flywheel or PP.
Old Sep 2, 2014 | 07:01 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: trans swap help
You would rather tear down a transmission than replace the clutch? I'd only recommend doing that if you already have another transmission to pull the shaft from. Even then I think you might have to re-shim it for clearances. I'm not entirely sure the two shafts are even swappable as the lengths may be slightly different. I can try to compare one of my cable shafts and hydro shafts later this week if no one can confirm the differences.
Honestly I'd have to say K.I.S.S. and just get the new clutch/pp/flywheel.
Old Sep 2, 2014 | 07:37 AM
So the HCD005U. This is a 21 spline clutch plate that is the same OD as my 20 spline so it should work with the existing PP and flywheel.
https://www.google.com/webhp?sourcei...34399603534823
Old Sep 6, 2014 | 04:57 PM
I figured I should follow up with my results. If anyone is trying to fit a 21 spline CRX HF trans onto a D15Z1 (being a cheap skate) by using the 1994 flywheel and PP. An Exedy HCD005U will work.
Old Sep 6, 2014 | 05:19 PM
whirley1's Avatar
My clutch disk kit was made foe a 92 civic dx but it fit my 91 civic dx. No problem to install it either
DamnThatsRexy
10
Jul 9, 2014 04:19 PM
CRXherbie91
Transmission & Drivetrain
Dec 11, 2012 12:57 PM
CPT Del sol
Apr 7, 2011 03:50 AM
CPT Del sol
Apr 6, 2011 10:08 PM
1SiC 3DR
Sep 1, 2006 02:21 PM
