S300 and boost control issue
Old Aug 31, 2014 | 07:47 PM
JDMCRX's Avatar
Default S300 and boost control issue
Hey guys ok the set up
Gsr turbo. Car runs 8psi with the aem tru boost set to duty of 55.
Now I ran the wire to A11 and activated it and no matter how much I changed the HZ or duty cycle I could not get the s300 to control boost.
Any ideas ?
I'm running a Mac boost solenoid btw.
Old Aug 31, 2014 | 07:59 PM
Muckman's Avatar
Moderator in Chief
Default Re: S300 and boost control issue
Do you have the pwm components installed on the Ecu?
Old Sep 1, 2014 | 04:28 AM
JDMCRX's Avatar
Oh yes forgot to mention the Ecu was prepped by hondata and I opened it up and checked all the resistors and transistors are installed and the previous owner had boost running on it.
Does anyone have the Mac boost solendoid on there s300 ?
Old Sep 1, 2014 | 02:58 PM
Natural Aspirations's Avatar
Take a screen shot of your settings.
Are you getting too much boost or too little?
Is your MAC normally open or normally closed?
Old Sep 1, 2014 | 04:28 PM
VegasInvasion's Avatar
I'm Huge In Japan
bad wiring/no diode, bad solenoid, bad calibration, boost leak, bad wastegate, bad turbo.
Old Sep 4, 2014 | 06:37 AM
JDMCRX's Avatar
The wiring is good. I hae the AEM tru boost running the solenoid now and its working fine.
The previous seller said the ecu was modified by hondata.
I tried changing the HZ and duty cycle and could not get it to work.
Does anyone have a snap shot of how they got a MAC solenoid setup ?
Turboed_Em1
Sep 4, 2015 03:45 PM
dk=gsr
Engine Management and Tuning
Feb 20, 2012 08:04 PM
Listerofsmeg
Feb 10, 2012 05:16 AM
sikasscivic
May 18, 2011 04:18 PM
bigtom388
Nov 21, 2009 12:30 PM
