Any way to test a crank position sensor??
Old Aug 31, 2014 | 04:01 PM
Rickmanalex's Avatar
Default Any way to test a crank position sensor??
01 accord 2.3 died while driving... New dizzy... new ignition switch... Power to the dizzy.... No spark... getting Fuel... Think it's the crank sensor.... all help is appreciated
Old Aug 31, 2014 | 07:45 PM
GhostAccord's Avatar
Default Re: Any way to test a crank position sensor??
Have you tested the ignitor?
I'm pretty sure the only sensor in the '01 distributor is the cylinder position sensor. The TDC and CKP are both located down behind the crank pulley/timing cover. There are also tests for those as well.
Do you have access to a multimeter to check resistance of the sensors?
T-Mo
May 11, 2012 05:56 PM
2000siturboR
Nov 6, 2009 03:29 PM
Beau Gotti
11
May 7, 2006 11:04 AM
who00knows
Jan 14, 2003 10:32 AM
prjctCIVIC
Aug 26, 2002 08:34 PM
