die and tap..tap broke off..now what.
Old Oct 31, 2002 | 07:50 PM
ILOVEGIRLS's Avatar
Default die and tap..tap broke off..now what.
is it possible to extract a tap that has broken off? its the thread that hold the thermostat so it hard to get pressure in there. help!! thanks.
Old Oct 31, 2002 | 07:57 PM
uNF$@#!'s Avatar
Default Re: die and tap..tap broke off..now what. (ILOVEGIRLS)
drill it out.
Old Nov 1, 2002 | 09:23 AM
ILOVEGIRLS's Avatar
Default Re: die and tap..tap broke off..now what. (Soup ****)
i dont think i can get a drill to fit there. its pretty much a small place.
Old Nov 1, 2002 | 09:24 AM
mojoGSR92's Avatar
What were trying to fix when you broke tap?
Where were you doing it (on the car I'm assuming?)
Old Nov 1, 2002 | 09:45 AM
maxxdout's Avatar
Default Re: die and tap..tap broke off..now what. (mojoGSR92)
you cant drill out a tap, you can try but probably wont work. A tap is made of carbide...pretty strong stuff.
Old Nov 1, 2002 | 06:06 PM
ILOVEGIRLS's Avatar
Default Re: die and tap..tap broke off..now what. (maxxdout)
i was fixing a bolt that was stripped. also..if the tap is so strong..how come it broke? a die set cant pull it out? thanks. it broke with very little pressure. any ideas? thanks
Old Nov 1, 2002 | 09:02 PM
stumpyf4's Avatar
You can drill it out with a carbide drill (or concrete drill if you're cheap like me), make sure you buy a few. There is a device called a tap extractor, it has prongs that fit into the channels in the tap, that may do the trick.
Taps have high hardness but are brittle, it will break not bend. You probably put too much side load on the tap, next time use a tapping fluid or oil to lubricate the tap. Also back out the tap occasionally, helps move the shavings and get oil to the cutting surface.
Old Nov 1, 2002 | 09:09 PM
cjohnson_2's Avatar
Default Re: die and tap..tap broke off..now what. (stumpyf4)
to the guy who said a tap extractor. taps are made of high speed steel. Very hard metal. only 2 ways that you can get it out, tap extractor(try this first) or a carbide drill (only do if #1 dosent work).
Old Nov 2, 2002 | 10:31 AM
ILOVEGIRLS's Avatar
Default Re: die and tap..tap broke off..now what. (cjohnson_2)
thanks guys. u guys know ur stuff, im gonna try it again today.
Old Mar 3, 2003 | 03:24 PM
integra6650's Avatar
i broke an easy out in my turbo it cost me 70 bucks to get out by a master machine shop
DC2Mex
Dec 12, 2012 07:10 PM
tree fingers
12
Sep 19, 2008 04:18 PM
Muckman
Welding / Fabrication
12
Apr 11, 2008 09:50 AM
hatch_
15
Feb 7, 2008 10:13 AM
Teglessb18
Jan 3, 2008 08:26 AM
