ignition issue
Old Aug 29, 2014 | 02:45 PM
LSVtechnologytur...'s Avatar
Default ignition issue
hey everyone,
I'm having a no spark issue with a obd1 ls motor swapped into an obd0 integra. I have the correct ecu, jumpers, distributor etc.. Grounds are all clean and tight.
i followed this
http://www.team-integra.net/forum/bl...eshooting.html
and i have not pulse from the negative side of the coil with a test light. I have replaced the ignitor and still have the same problem.
My question is, what is the next step? everything else in the diz. seems to check out. I have swapped everything in the distributor with a spare and still have no spark.
thanks
civicjdmb16a
Oct 15, 2006 07:05 PM
civicjdmb16a
Oct 13, 2006 06:26 PM
CptCorN
Jan 17, 2005 06:33 AM
stivic
Sep 17, 2004 08:44 PM
