1994 Accord IAR Check Valve Trying to Identify
I am thinking of buying a 1994 Accord and trying to figure out what the name of a hose is.
There is a vacuum hose that is dry rot and severed. I think I found the hose in the Haynes Repair Manual for that year. It shows it as the "IAR Check Valve".
But searching the archives here and googling I am not finding much information.
I found a thread in the archives here that said there is a vacuum hose diagram on the reverse of the hood but this car has a replacement hood and does not have any diagrams on it.
I have attached two photos. Am I right that the hose is the IAR Check Valve? Or is this hose something else? If it is the IAR, is there another name this hose is known as?
The AC does not work on this car but everything else appears good (according to a mechanic who looked it over and pointed it out and told me it was a "f****** vacuum hose")
u could try majestic honda or hondaautomotiveparts.com (same thing) and look up the diagram to find the part
also download a Factory Service Manual
Thats the air intake solenoid vacuum hose and it has a check valve which is busted.
http://www.hondapartscheap.com/auto-...chamber-b-scat
Parts 8, 20, 22 but it might be cheaper to buy a couple rolls of bulk hose and redo all your vacuum hoses while you're at it.
http://www.hondapartscheap.com/auto-...pe-tubing-scat
Part 14
Part 14
senor honda
May 22, 2007 11:03 AM
