TYPE R OEM vs AFTERMARKET suspension
Old Aug 28, 2014 | 09:47 PM
Mccormick009's Avatar
Default TYPE R OEM vs AFTERMARKET suspension
I just picked up a type r with form and function type 2 coil over. Have them set pretty high and on softest setting and they just suck on the road. Way too stiff and bouncy to be enjoyable.
Is the stock ITR suspension pretty good for mountain roads and street? My car will be driven a lot in traffic and taken out on weekends for fun on back roads
Old Aug 28, 2014 | 10:11 PM
Turb0wned's Avatar
Default Re: TYPE R OEM vs AFTERMARKET suspension
Yes stocks are very good on this car. Only reason I'm not running the stocks instead of my Tanabe coilovers is because I wanted the car a little lower.
Old Aug 29, 2014 | 03:13 AM
Xian's Avatar
Another +1 for the stock springs. They're plenty good for street and light Autocross use. I'd suggest pairing them with some Koni or Bilsteins and (depending on driver familiarity with loose FWD'ers) a larger rear bar. The other option would be a jump to a high end shock (MCS, Moton, JRZ, Penske, JRi, etc) as they have spectacular street manners. Often times the issue with JDM y0!!!1 shock brands is way the hell too much high speed compression. A decent shock package will allow you to run higher rates while providing a better ride as well.
Old Aug 29, 2014 | 04:13 AM
CW-ITR's Avatar
Originally Posted by Mccormick009
..... on softest setting and they just suck on the road. Way too stiff and bouncy to be enjoyable.
In this case, you are the prime candidate for a set of OEM ITR shocks and springs. Just remember, like any other "progressive" springs, the ITR progrssive springs are designed for the ITR stock weight. If you light weight it to a good amount, the ITR springs will create an off road look fender gap and your caR will corner like a carriage. LOL
Old Aug 29, 2014 | 06:02 AM
R6Elmo's Avatar
stock springs are best for street. If you want lower then maybe stock springs + koni shocks on the lower perch.
I had eibach multipro prior and they actually had good street manners. I feel the other shocks have too little compression for the street on lowered cars.
Old Aug 29, 2014 | 06:23 AM
Tight-R's Avatar
I have a low mileage set of stock springs/shocks I could sell if you can't find any.
Old Aug 29, 2014 | 07:44 AM
I would be very interested. How much, mileage and location?
Thank you all for the feedback. I dont plan on stripping out the car so it sounds like weight wont be a concern.
I also dont really want to lower the car much. I havent seen a stock ITR in ages but on the highest setting on these coilovers the car is so low. My wife will occasionally drive it and the front lip has already seen love because of it.
Old Aug 29, 2014 | 07:48 AM
Todd00's Avatar
I said I don't want a title!
F&F Type 2 coilovers are like $850 shipped. They are not the cheapest of the cheap, but they are pretty darn close.
OEM springs on koni yellows (on the bottom perch) should give you what you are looking for.
Sell your F&F's on craigslist for like $300 and make some ricer's day and recoup some cash.
Old Aug 29, 2014 | 08:07 AM
aw614's Avatar
10 Year Member
Loved
F&Fs are another Bor Chaun branded coilover like megan, ksport, etc, seems popular with the stance kids...
I'm happy for the most part with how the OEM ITR shocks perform with bilstein sports, I'd say I can probably leave this set up on my car for a long time with a set of good tires as long as I dont get the moar low bug lol.
Old Aug 29, 2014 | 12:47 PM
white rocket's Avatar
+1 for Koni yellows and OEM ITR springs. Very minor ride height drop and great street mannerisms for sharp bumps. If you aren't prepared to spend some serious $$$ on high end coilovers then this is your best bet. Like Todd00 said, sell the F&F on CL and recoup some bread.
Old Aug 30, 2014 | 12:55 AM
gwh0803's Avatar
I thought my OEM suspension was quite good until I hit the autocross track, where the car's body roll was literally like a pirate ship.
Went aftermarket for buddy club RSD afterwards. Yes, they're a lot stiffer even at the softest settings, but guess there are compromises to be made...
Old Aug 30, 2014 | 07:22 AM
aw614's Avatar
10 Year Member
Loved
what was the mileage on the oem suspension, I put on higher mileage itr shocks and it was horrible for autox, but taught me a lot with the slow reactions the worn shocks were giving me, changing the shocks made the biggest difference, while retraining the stock springs and sway bars.
Old Aug 30, 2014 | 09:19 AM
Xian's Avatar
I'd also be suspect of worn out or compacted OE bumpstops. The ones on my 97 were toast by ~70k miles. The result was a ton of pitch and roll... The swap to higher rate bumpstops and revalved Bilsteins transformed the car.
Old Aug 30, 2014 | 11:01 AM
With these comments, how long do stock shocks last on these cars?
Old Aug 30, 2014 | 01:26 PM
aw614's Avatar
10 Year Member
Loved
I'd say probably around 80k to 100k depending how they were driven maybe more if they arent tracked and you live in an area with good roads. The set of shocks I bought came with H&R lowering springs so Im assuming they probably wore the shocks out even more.
Mine drove fine on the street, taking it to autox was when the issues became more apparent that something wasn't right. Some higher speed sweepers I'd completely lose control of the car when I lifted, it was sudden and not fun.
The best thing you can do is have fresh bushings all around and new shocks/bumpstops.
Old Aug 30, 2014 | 02:30 PM
I think Im going to go with used set of OEM setup and refresh any bushings that look ill. The car doesnt currently have any existing stock suspension. All were removed with ff coilover instal including rear lower control arms. I will need to have the springs, hats, pillow mounts etc.
Once the shocks wear out I think the Konis should work. I will be doing very little autox. Just mainly freeway/street and occasional mountain road rampage.
Thanks all for your help and guidance!
Old Aug 30, 2014 | 05:23 PM
b18c5 power's Avatar
I just installed koni yellow and Tein.H springs ;I think I got the best of both worlds...
Well koni yellow are A+ (middle perch) Tein.H really mild drop + slightly stiffer spring rate but not by much !
Old Sep 3, 2014 | 11:15 PM
allyourapex's Avatar
I think I actually prefer the OEM shocks compared to the Koni Yellow's with stock springs, for street driving anyways. Autocross and track use the Koni's are fine, but daily driving I've been fairly disappointed.
Old Sep 4, 2014 | 05:13 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
I currently ride on Bilstiens with GC sleeves/springs. To me it is way too bouncy for daily street driving.
I just picked up a set of Koni Yellow Sports and going to use the Koni Yellow/Ground Control setup. With them being adjustable, Im sure ill be able to find a comfortable setting.
In the Yellow girl, I have Ohlins DFV suspension. That is insanely responsive. Ride is fantastic. Holds and devours turns. I havent even messed with the tons of adjustments yet but it really is a amazing how well it performs.
Old Sep 4, 2014 | 12:51 PM
Xian's Avatar
For the Bilsteins, I thought they were super comfy with ITR springs. What rates are you running? Also, do you have enough bump travel to keep it off the bumpstops?
Old Sep 10, 2014 | 06:39 PM
tony_2018's Avatar
Fish Twig
The oem type r's has done well for me as well. However they are hard to come by unless you buy them new.
Old Sep 10, 2014 | 07:24 PM
I use Ohlins on my bikes. My goodness they are good. Best in world by far. Not really looking to go that crazy on this DC2 though
I have also driven this setup and loved it. I would pick this as my first choice but I just want a relatively cheaper option to bring car back to stockish fun for road and mountains.
If I could find the Bilsteins and stockers cheap enough Id jump on it but I can't even find stock springs and perches...
Old Sep 11, 2014 | 07:37 AM
Xian's Avatar
Whats New At hmotorsonline.comŽ 1994-2001 Integra's
Part way down the page... $200 for stock shocks/springs.
Old Sep 11, 2014 | 06:13 PM
UPDATE: Bought stock ITR shock/spring setup. I will let you all know my thoughts when I get them installed. I can't wait to get this garbage Form & Function off...
Old Sep 17, 2014 | 03:35 PM
shahriar35's Avatar
Can you explain why you were disappointed in the streets?
