Help interpreting results of compression test
Old Aug 27, 2014 | 11:35 AM
eac705's Avatar
Default Help interpreting results of compression test
I just did a compression test in the vehicle.
My crankshaft pulley fell off, fixed everything to the best of my knowledge. When I crank the vehicle, there is white smoke that comes out of the exhaust. It seems the clear up as the vehicle idles.
When the vehicle idles it seems to run decent 1200 -1400rpm (330k miles) however it seems to want to throttle down to 500 rpm to the point that it sounds like it would die but I throttle it and it perks back up.
I did a compression test and the results were
#1 133
#2 174
#3 175
#4 174
Someone told me bent valve, another friend said that if it get's that much pressure then it could be something else.
The car isnt worth much money, but I'm strapped for cash at the moment. Trying to keep this car running for just another 12 months and then my wife's car will be paid for and I can afford to find a used replacement. Thanks guys.
Old Aug 27, 2014 | 02:03 PM
holmesnmanny's Avatar
Leakdown test will tell you if its bent exhaust valve bent intake valve or head gasket.
Old Aug 28, 2014 | 06:50 AM
uberEFtuner's Avatar
Default Re: Help interpreting results of compression test
Do the compression test again. But this time remove the valve in the compression tester. Then watch how fast each cylinder loses pressure. If it has a burnt valve it will leak out very quickly. Also you can turn the motor by hand and blow air into the spark plug hole. If you hear air coming from the exhaust or intake, you have a burnt valve.
civic-one
Apr 6, 2011 08:02 AM
MilFhunter001
May 13, 2010 08:29 AM
turbosivtec
May 24, 2009 04:33 PM
94_civic_tuner
Oct 10, 2007 02:00 PM
JFG Kevin
Jul 19, 2006 07:49 PM
