1994 accord ex-r engine shutting off when coming to stop
Hi my car is automatic and lately my car has shut off randomly when coming to a full stop at a light, turning left/right, even sometimes going down a hill.. after it turns off i am able to turn it back on normally but this is getting annoying now. ive had an un certified mechanic look at it but he couldnt find the problem. even with full tank of gas it still happens.
Gently lift the iacv off after removing the two bolts and check the outer metal mesh filter and see if it's clogged up. Use carb cleaner to clean it.
thank you for the replies. after my post i had to leave for work and along the way i came to a stop at a light and 5 seconds later it turned off again -.- ! i will check up tomorrow morning and will update you guys! thanks again
CricketThomas
12
Jan 30, 2017 06:37 PM
NIKE4FRESHH
Feb 8, 2009 12:44 PM
zak88lx
Jun 5, 2007 01:33 PM
exile29
Mar 8, 2006 05:16 AM
