Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
DTC P1457
Old Aug 25, 2014 | 11:54 AM
Johnnnnnn's Avatar
Default DTC P1457
Check engine light came on. Pulled code P1457. After reading a bunch of post about this code they suggest changing the ( canister vent shut valve )
The ( purge valve ) and the ( 2 way bypass valve ).
Can anybody show me or send a diagram of where these parts are located.
Any help would be greatly appreciated.
Thank you
Old Sep 16, 2014 | 10:47 AM
mandycondo's Avatar
Default Re: DTC P1457
Hey guys,
I have a Honda Civic 2001.
Its giving me the P1457 code.
I have to pass an emissions test this month.
1. Can I unplug the battery (or remove the right fuse) to turn off the Engine light and then replug the battery wires, drive to the test, and pass it that same day???
2. Does removing the battery power reset the code P1457 ?
3. If my Engine light turns off does that mean the computer wont issue a P1457 error code when hooked up to the emission system?
-Mandy
wehnerdy
Mar 30, 2017 10:56 AM
derrickjon
Oct 23, 2016 04:17 AM
DrJBCEsq136
Dec 3, 2014 08:18 AM
pclouthier
Jul 6, 2014 03:01 AM
dw31
Jun 4, 2013 08:40 AM
