need help doing rear disc swap on a 2000 hatchback
Old Aug 23, 2014 | 10:57 AM
MagicJ_2000cx's Avatar
Default need help doing rear disc swap on a 2000 hatchback
i could search internet for answer but i wanna be 100 percent im getting the right part im swapping on sir civic rear disc and do i need to change entrie rear line or just the little ruber hoes at the end to sir line cause i know i gotta chage brakes just dont wanna do more then i have to thanks
Old Aug 23, 2014 | 11:01 AM
EsotericImage's Avatar
Retired Moderator
Default Re: need help doing rear disc swap on a 2000 hatchback
Its easier to swap the whole trailing arm and replace the bushings while theyre out.
Old Aug 23, 2014 | 11:28 AM
Bob Dole!'s Avatar
I assume you're talking about brake lines? You don't need to replace the hardline, only the rubber soft lines from the body to the rear calipers.
Old Aug 23, 2014 | 01:31 PM
eHMxhACk's Avatar
yippee-ki-yay
You'll also need the four small washer that go on either side of the banjo bolts. Two washers for each bolt, one bolt per side.
eH.
Old Aug 23, 2014 | 09:20 PM
can u show pics for reference where can i get brake lines
Old Aug 24, 2014 | 07:07 AM
Bob Dole!'s Avatar
http://www.hondaautomotiveparts.com/...y5=BRAKE+LINES
You need numbers 20, 21, 28, 29.
Does your brake swap come with a prop. valve? Because you'll need that too. (No. 4)
I assume you're swapping the entire trailing arms?
Old Aug 24, 2014 | 12:03 PM
eHMxhACk's Avatar
yippee-ki-yay
Originally Posted by Bob Dole!
You don't need to order 21, because 28 and 29 included 21. But you will need to order two 20s.
eH.
Old Aug 24, 2014 | 04:24 PM
Bob Dole!'s Avatar
eH.
Good catch
jdblock
Northern California (Sales)
Feb 1, 2018 12:03 PM
qat727
Dec 14, 2006 07:59 PM
civicracer94
Aug 29, 2006 11:48 AM
sloweredcivic
15
Mar 16, 2005 09:12 PM
