91 CRX HF Crankshaft Pulley?
Old Aug 22, 2014 | 01:16 PM
us31wking's Avatar
Default 91 CRX HF Crankshaft Pulley?
SO... I lost my crankshaft pulley and turns out the part is discontinued by Honda. Is there any crankshaft pulley that is guaranteed to work?
Heck, I can't even find an aftermarket one specifically made for my car.
Old Aug 22, 2014 | 01:30 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: 91 CRX HF Crankshaft Pulley?
See below for correct info
Old Aug 22, 2014 | 01:39 PM
jlicrx's Avatar
for 88-91 CRX, the DX Si HF crank pulleys are interchangeable - most 88's and some 89's had a crankshaft with a 22mm diameter front snout - most 89's and all 90 and 91's had a 24mm snout - you would need a pulley for the 24mm snout - the reason they have different part numbers is that the ignition timing for the HF is 4 degrees different from the DX and Si and the marks on the pulley are in a different location due to this - DX and Si is 18 degrees BTDC and the HF is 14 degrees BTDC
Old Aug 22, 2014 | 01:42 PM
24TEN's Avatar
PHANTOM MENACE
I stand corrected
jlicrx - Then would the 92-95 CX and 96+ still be a viable option?
Old Aug 22, 2014 | 01:55 PM
jlicrx's Avatar
Originally Posted by 24TEN
I stand corrected
yes
Old Aug 22, 2014 | 01:58 PM
24TEN's Avatar
PHANTOM MENACE
Nice. I'm glad people like yourself are still on here sharing knowledge.
Old Aug 23, 2014 | 04:30 PM
us31wking's Avatar
So in terms of installation, the 4 degree difference means what exactly?
Thank you for insight by the way!
Old Aug 24, 2014 | 11:23 AM
24TEN's Avatar
PHANTOM MENACE
Nothing, it only installs one way. The 4 degrees difference is relative to the ignition timing marks.
craigboostedrex
Apr 6, 2011 07:25 PM
pauley01
Aug 8, 2007 05:15 AM
Tyson
35
Dec 30, 2004 03:06 PM
