crome - GOLD MAP vs P30 BASE
Old Aug 21, 2014 | 05:28 PM
gabrielsousa's Avatar
Default crome - GOLD MAP vs P30 BASE
i'm trying to use the gold map
i copied the fuel and ign map of the p30 to gold.
on GOLD the idle isnt smooth like p30
on GOLD shakes a little more and have small popping.. that i don't have on p30
is the battery injector offset ? its strange because i have a b16a1 (original pw0 obd0) runing with obd1 p28 ecu, but i have obd0 injectors... and set on GOLD 87-91 injector...
any ideas ?
Old Aug 21, 2014 | 06:31 PM
bgdriver's Avatar
Default Re: crome - GOLD MAP vs P30 BASE
I had p30 running and then switched to gold. I have the same issue with the popping. If you watch ignition timing on the datalogs, it randomly pulls timing even with all corrections at 0. I am going to switch back to p30 base.
Old Aug 22, 2014 | 03:06 AM
I change the IAT ign and fuel correction all to 0 , and i have a much stable ignition on GOLD,
but the idle isnt smooth like p30, i think is the injector offset conf.
@bgdriver what car you have ?
Old Aug 22, 2014 | 07:06 AM
deleted duplicated potst
Last edited by gabrielsousa; Aug 29, 2014 at 02:20 AM. Reason: deleted duplicated potst
Old Aug 26, 2014 | 02:27 AM
"It's not the same fuel multiplier so it runs leaner on gold maps, you just need to tune it." - Miles David
@bgdriver
try to give more 15% to 20% fuel on the map
did you test with wideband ?
i rise 15% on mine, and now GOLD idle is like p30
Old Aug 28, 2014 | 06:59 PM
VegasInvasion's Avatar
I'm Huge In Japan
He emailed me personally about this but I figured I should post the answer. In some P30 bases, the individual cylinder trim is doubled. If you double it in the Gold file, it should level out. It still won't be very accurate though, so instead of messing with cylinder trims you should just tune it.
Old Aug 28, 2014 | 07:09 PM
I'm Huge In Japan
there is no reason to make two threads about this. merging.
Old Aug 29, 2014 | 02:16 AM
@VegasInvasion
thanks a lot for your help
on p30 base the multiplier of the cylinder is 1 ...
Old Aug 30, 2014 | 11:43 PM
I'm Huge In Japan
the gold rom was developed on p30. if your individual cylinder trims are all 1.00 in p30 then there shouldn't be much of a difference. either one of your parameters is inaccurate in the gold rom or you have a bad gold base and need a new one.
cyanid3
Engine Management and Tuning
10
Nov 9, 2009 10:12 AM
champwhiteEG6
Jul 10, 2009 07:52 AM
Linus_E
Mar 29, 2005 09:07 AM
nickromeo
Feb 10, 2004 08:33 PM
scatuli
Sep 15, 2003 02:04 PM
