Adjusting valves 2001 CR-V
I'm wanting to adjust the valves on 2001 CR-V and it would be great if anybody has any advice/information on the best way to complete this task
Also I'm worried that I'm to late in adjusting them because the rpm drops rapidly when I start up the car but then goes back up to idle rpm in 10ish seconds, is this an indication that my valves are burnt and how would I conform this?
http://lmgtfy.com/?q=Adjusting+valves+2001+CR-V
The first one that pops up is the one i use
(How to adjust your valves, 97-01 CRV)
I adjusted mine and it did the trick....should be adjusted about every 30K miles. Unfortunately Honda said valve adjust at 100k which was too late. .005 fuel /.008 exhaust. +/- .001
