P05 ecu with b18b1 swap
Old Aug 20, 2014 | 09:15 PM
Damonsdaddy's Avatar
Icon6 P05 ecu with b18b1 swap
Obd1 p05 ecu in my 95 cx hatch with a b18b1 us swap and it's warming up funny and the rev limiter is kicking in at about 3500 rpms in second gear why I'd this ecu even working? And I tried a pr4 today and my car wouldn't even start, when I Change the ecu do I need to disconnect the battery or not? I know on that last ? I'm gonna get a lot of mixed contradictions but I'm open to opinions!
Old Aug 23, 2014 | 04:04 PM
Default Re: P05 ecu with b18b1 swap
Any help? I bought another pr4 and tried it my car wouldn't start the guy said something about the wiring and he could fix it but didn't really explain and now he's bs'n me! Any help please tell me I don't have to get it chipped?!
Old Aug 25, 2014 | 12:00 PM
stupidhard's Avatar
I think you got the wrong ecm all together. I think you need a P74. you didn't give much info on your vehicle... its a cx so that swap should have been plug and play with the p74 engine, harness, and ecm.
unless there is some reason for running a different ecm. you really didn't specify.
-chris
Old Aug 25, 2014 | 02:50 PM
spAdam's Avatar
Loved
Community Favorite
WTF is a P74 ecu?
Correct ecu for an obd1 B18B is the P75. As far as I know you can chip the CX ecu just like any other obd1 ecu, but yeah... it should run like total **** on that stock map. How stock is the motor?
Old Aug 26, 2014 | 05:01 PM
HiProfile's Avatar
94-95 P75 ecu would work. The p05 probably doesn't give enough fuel past 3500rpm to let the b18 run well enough.
PLEASE check if you have any error codes, it is IMPORTANT. If you are getting a code 4 or code 9, then look into the distributor wiring.
Old Sep 3, 2014 | 01:37 PM
stupidhard's Avatar
Originally Posted by spAdam
WTF is a P74 ecu?
OBD1 LS ecu.
the p72 is for the b18c...
how wrong am I? seriously... if im wrong I wanna know.
-chris
Last edited by stupidhard; Sep 3, 2014 at 06:02 PM. Reason: hondapartshero corrected me... thanx
Old Sep 3, 2014 | 03:12 PM
HondaPartsHero's Avatar
Technical Hero
There are 3 ECUs that are OBD1 that would work, P74, P75 and PR4. P72 is for the B18C1 GSR engine.
Old Sep 3, 2014 | 06:00 PM
stupidhard's Avatar
^thanks hero.
Old Sep 3, 2014 | 06:16 PM
spAdam's Avatar
Loved
Community Favorite
Originally Posted by stupidhard
OBD1 LS ecu.
-chris
Searching around, I occasionally see a mention of P74, but it's usually associated with the P75 (Hondata, etc just says P74/P75) or given with an bogus, incomplete number (like 37820-P74-XXX). Doesn't come up in the fiche for -A0x for x = 1-9... It's almost like a gap in the number got filled in and it just became part of the lore. I've definitely never seen one.
I might be wrong, who knows... wouldn't be the first and surely won't be the last time
Old Sep 4, 2014 | 06:30 PM
stupidhard's Avatar
ok, cool. didn't realize they were the same... or that the difference was negligible.
thanks spAdam!
-chris
GT500FTW
Nov 5, 2012 09:57 AM
BumperLT
Engine Management and Tuning
Sep 11, 2008 09:50 AM
JohnnyWash1
May 3, 2008 07:58 AM
mrx
Mar 28, 2005 05:56 AM
