tig welding gas coverage ??
Old Aug 20, 2014 | 06:08 PM
v8killaz's Avatar
Default tig welding gas coverage ??
so I just had a quick scenario at work. I wanted to see if I can use a separate hose running argon to shield the tungsten
meaning I turn off my gas from my machine and then turn the gas on an argon tank to flow whatever cfm I'd run.
So I go about trying this, I hold the gas hose right against the tungsten from the other argon tank while my machine's tank is shut. I tap the pedal and nothing, same thing as if no gas was flowing. I try again at lower cfm and still cant get a tack weld. Basically holding the gas hose to the tungsten did not work at all for shielding. Im asking why not?
Also I got a question about purging a stainless fuel tank, first of all can I purge with nitrogen. and what cfm should I fill the fuel tank with and then how long should I wait and how many cfm should I set it at while welding. I am getting no sugaring but setting the purge at 25cfm. But the inside weld is grey. These fuel tanks are stainless steel
this is the size of the tank. all the holes are covered and gaps taped up
Old Aug 21, 2014 | 01:44 PM
para pat's Avatar
Default Re: tig welding gas coverage ??
Your machine might not initiate an arc if it senses no gas flow.
Yes, you can purge with nitrogen but because its not an inert gas, you will not get any coloring in the weld. Use it exactly like you would an argon purge
Old Aug 22, 2014 | 05:16 PM
v8killaz's Avatar
yeah but the thing is it does initiate an arc.
Old Aug 22, 2014 | 06:27 PM
Luserkid's Avatar
For your machine arc question, are you holding argon hose from the side to side of your arc or did you hook up your torch to that extra bottle/argon source? If its side to side you probably wont get a good arc because the argon is blowing out your arc from left to right oppose to up and down. What you could do if your machine isnt releasing gas correctly is hook your gas line directly to your argon. The problem with doing this is that you will waste alot of gas between welds and what not.
For your purge question are you talking welding from the inside out or the outside in? From your pic it looks like inside out and if thats the case you could make a little purge box and tape it to each spot your welding on for the time then move to the next. If you do the box I would only run about 15cfm or so as the box will do most of the work. Now if your welding outside in depending on the size of the tank i would do full blast argon from bottom with exit on top for 10-30 mins. while rotating the tank so argon can get to every corner and area before letting it sit. Then set it down to about 35-40 depending on how big the exit is and how sealed up the part is.
Old Aug 22, 2014 | 11:50 PM
v8killaz's Avatar
yeah im holding the gas hose to the torch(tip of the tungsten). I guess you right, doesnt make too much sense to me but whatever.
and im purging the entire tank. and welding from outside, thew welds inside are just all the baffles and whatnot
Old Aug 31, 2014 | 04:17 PM
Engloid's Avatar
OG Fabricator
Purging with nitrogen really won't give a nice clean color. It can prevent sugaring, but if you are worried with color, go with argon.
Old Sep 8, 2014 | 10:02 PM
v8killaz's Avatar
alright. im having better luck now setting purge lower cfm like 10cfm and making sure the other leaks are sealed up expect the one im welding. less arc wander with lower cfm and better penetration and color.
delante(ej1)
Apr 7, 2013 10:14 AM
mahatma
Nov 27, 2006 08:14 AM
b16hybridsol
Welding / Fabrication
12
Apr 11, 2006 09:50 PM
HondaHemi
Dec 3, 2005 05:51 PM
null.
Jun 22, 2005 07:03 PM
