Guess where my PCV valve was hiding. D16Y8
Old Oct 31, 2002 | 04:54 PM
EL'ation's Avatar
Default Guess where my PCV valve was hiding. D16Y8
For most cars, it's simpliest thing you can change under the hood. Usually takes 30 seconds to do it but not with our D16Y8 engines.
I bought a new PCV valve last year and tried to change it. But I coulnd't figure out where it was located until yesterday. I jacked up the car to change the oil and removed the oil filter.
Suddenly I decided to change the PCV valve( I heard I have to get under to change it). I put the flashlight where the PCV hose(?) goes into (b/w 2nd and 3rd injector area) and looked from under the car.LOL,I could see the PCV valve right above the oil filter(filter is off now). It is impossible to change it without taking your filter out, and it is still bitch to get it out of. DOn't bother trying to pull it out with your fingers. Just get a flathead crew driver and pop it.
Anyone can fit their hand into this hole ? Guess not.
See how long it is.
Wish I could take some pictures from under the car but my hands were to dirty to take a picture.
I'm posting this because everytime I or other D16Y8 people ask how to change the PCV valve, no one really answered correctly. Some shops told me to just pull it hard from the top. I tried but it was too tight, Thank God.
Old Oct 31, 2002 | 05:21 PM
thinkbrianthink bu's Avatar
Default Re: Guess where my PCV valve was hiding. D16Y8 (EL'ation)
1. you can use needle nose pliars to get to it from the top
2. what are the extra letters on your valve cover?
Old Oct 31, 2002 | 05:30 PM
EL-Driver's Avatar
Default Re: Guess where my PCV valve was hiding. D16Y8 (thinkbrianthink)
I think this it what is says..
1.6 SOHC VTEC
Honda Motor Co.
I should know this because I own the same car, the valve cover is for an Acura EL (its Canadian EH!!)
Old Oct 31, 2002 | 07:24 PM
civic dx's Avatar
never seen that valve cover before
Old Oct 31, 2002 | 07:48 PM
Mr. Thunderlips's Avatar
See how long it is.
Well son, any lady that lives in a 20 mile radius of myself can attest to that.
Old Oct 31, 2002 | 08:30 PM
EL'ation's Avatar
Maybe, maybe you can get it off, but how are you gonna put it back?
I can't really picture something goes into that hole and take the PCV valve off.
It was so tight, I had to use a screwdriver. Oh, and it's in sideway so you can't pull it towards you.
Have you done it from the top?
Like others said, It's an Acura EL cover.
[Modified by EL'ation, 12:33 AM 11/1/2002]
Old Sep 9, 2004 | 07:33 PM
AgentJam's Avatar
Bump...need a pic of this from somebody please!
Thanks,
Vince
Old Sep 10, 2004 | 04:16 AM
AgentJam's Avatar
Default Re: Guess where my PCV valve was hiding. D16Y8 (AgentJam)
please
Old Sep 10, 2004 | 06:22 AM
edunnett's Avatar
I have an EW1 type engine in an '86 Civic Wagon. I spent about two months searching for the PCV valve, replacement in hand and convinced myself that there was none - that the previous owner must have removed it and not replaced it! Finally, after a very long time looking, I found it in the same place you describe. I tried to access it from the top but my hands are WAY too big, have been since I was 4 yrs old! And from the bottom, the oil filter was in the way of even being able to see if it were possible. I took it to a shop and had them do it - they said they had to remove the manifold I think. It was terrible - cost $150 to replace a $6 part! Now that I know you were able to access it from below... I may try that in a few years when it has to get done again. As for photos, I can insert one of those later today.
Elissa
Old Sep 10, 2004 | 08:29 AM
AgentJam's Avatar
Default Re: Guess where my PCV valve was hiding. D16Y8 (edunnett)
yeah thanks, i have a y8 engine sitting in my garage however the previos owner may have removed the pcv valve because they put a z6 manifold on it which has the valve on the top. Just need to know what a stock y8 pcv valve looks like and where it should go.
Vince
Old Sep 10, 2004 | 09:19 AM
edunnett's Avatar
See the small red circle indicating where my PCV hides. It's hard to see in this image... but if I removed the intake/airfilter and found the fuel filter (follow red hose from fuel pump to the right and it connects with the aux fuel filter in this car) the PCV hose is located in the engine compartment behind the aux fuel filter. The hose looks like any other fat vacuum hose with clamps on it - nothing remarkable. The PCV valve is within the hose on this car. If I removed the clamps holding the hose in place, the PCV valve on this car would then be visible. There is a black grommet covering the short (1.5 inches) and thin metal valve. YOu can see the drawing for where it is on your car by going to http://www.hondaautomotiveparts.com (website for Majestic Honda) and making like you're going to buy a part for your car... they give a whole schematic for every different system with everything labled. Hope that helps you find it!
Elissa
Old Nov 26, 2016 | 12:07 PM
Florian Ogasa's Avatar
1.6 SOHC VTEC
Honda Motor Co.
i have the same
Old Nov 26, 2016 | 10:28 PM
eghatch9295's Avatar
Stancetard Hate Monger
derp
CompSyn
24
Sep 26, 2016 02:16 PM
SportEL
Oct 20, 2012 12:21 AM
Navy_Kyle
Apr 6, 2011 05:16 PM
cehcivic15
Sep 11, 2008 06:46 PM
Chez'sExCoupe
Oct 9, 2005 08:17 PM
