2000 Honda Accord clutch does not engage starter
Old Aug 20, 2014 | 08:28 AM
joeysloop's Avatar
Default 2000 Honda Accord clutch does not engage starter
I have a 2000 Honda Accord that will not start when I turn the ignition key. There is no noise when I turn the key all the way so it is not a problem with the battery or the starter. It acts like I am not pushing the clutch all the way. I am guessing there is a switch somewhere that engages the starter when the clutch is pressed in far enough but can find no such switch. Would anyone please help me locate this?
Old Aug 20, 2014 | 08:36 AM
OMG's Avatar
OMG
Default Re: 2000 Honda Accord clutch does not engage starter
the clutch switch is near the clutch pedal
check if both wires are connected to it
Old Aug 20, 2014 | 11:19 AM
joeysloop's Avatar
I've crawled underneath and looked but the only switch I can find is the one that disengages the cruise control. Would you happen to have a picture or diagram of the switch location?
Old Aug 21, 2014 | 07:58 AM
OMG's Avatar
OMG
Can you take a pic of your pedal assembly
Here is a diagram
Old Aug 21, 2014 | 08:01 AM
OMG's Avatar
OMG
Old Aug 21, 2014 | 08:39 AM
hondaracing84's Avatar
I had the same problem with my civic. What happened with mine was, there is a little rubber stopper at the top the of the pedal. Mine broke off. All I had to do was purchase a new one from honda and put it in.
So check the very top of the pedal where the pedal pushes against the switch and see if the rubber stopper is still there or if there is just a hole.
BigPapaBear
Jun 26, 2017 04:38 AM
Drummerguy
Jun 9, 2017 08:19 AM
Nikki Aulicino
Jan 26, 2017 10:25 PM
94eg!
Jan 7, 2011 07:05 PM
-RedneckDave-
Aug 15, 2005 11:04 PM
