Power steering leak(pics)
Old Aug 19, 2014 | 11:21 AM
jmccalip's Avatar
Default Power steering leak(pics)
I need help figuring out what is leaking. Is it the pump itself?
http://imgur.com/a/z14tU#0
Thanks
Old Aug 19, 2014 | 12:13 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Power steering leak(pics)
Buy some simple green.
Liberally spray all the oily/greasy areas with simple green.
Allow the simple green to soak in, then hose it off.
Start engine, look for leaks, if none found, go for a drive that has a few turns. Open the hood and see if there are any new leaks.
Old Aug 19, 2014 | 04:14 PM
holmesnmanny's Avatar
All three of your rubber ps hoses need to be replaced and you need to rebuild your ps pump. The pulley bolt is reverse threaded but other than that its really easy to take it apart and redo all the orings and seals.
94 accord typeR's Avatar
chances are its the pump seals inside the unit. there are rebuild kits available and a tutorial on youtube.com explains the whole process in detail. its also worth noting that the system holds a total of 1.1 litres, so its probally worth it to just put in new fluid with the seals
Old Aug 19, 2014 | 04:27 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Clean it up, replace the $3-$4 O-ring, and fluid with Honda power steering fluid and see where it stands after that.
Honda TSB 98-023
FMohlmann
Nov 18, 2016 12:28 PM
blackj30_a
Sep 4, 2016 06:01 PM
professorman
Feb 24, 2012 06:52 PM
roydogg
Jul 17, 2003 11:12 AM
