Rack and Pinion question!?
I have a 94 Del Sol S model with a JDM D15B Vtec swap in it. Looking to replace my power steering rack. Ive seen them with two port holes and three port holes and Im not sure which one to get. Can anyone help me out?
well there is a site that you can plug your vin# in and you will for sure get the rite part.
sounds like the rack with three ports is a speed variable steering rack. usually the type of thing used on higher trim level vehicles.
idk what the site is, someone wanna chime in here?
Sometimes getting the exact match won't work because it could've been replaced with a different setup. A picutre of your current setup can help the company you are buying it from. Also sometimes the part # is stamped on the rack as well so maybe you should take a look at it.
honda_racing101
Mar 2, 2007 12:28 PM
