Rack and Pinion question!?
Old 08-19-2014, 10:27 AM
tgordenDELSOL's Avatar
Default Rack and Pinion question!?
I have a 94 Del Sol S model with a JDM D15B Vtec swap in it. Looking to replace my power steering rack. Ive seen them with two port holes and three port holes and Im not sure which one to get. Can anyone help me out?
Old 08-19-2014, 06:34 PM
stupidhard's Avatar
Default Re: Rack and Pinion question!?
well there is a site that you can plug your vin# in and you will for sure get the rite part.
sounds like the rack with three ports is a speed variable steering rack. usually the type of thing used on higher trim level vehicles.
idk what the site is, someone wanna chime in here?
Old 08-21-2014, 06:10 AM
delsol-101's Avatar
to make everything easy on you i would say get the exact on you have now depending if u have a 2 or 3 port.
Old 08-21-2014, 06:15 AM
Fish Twig
tony_2018's Avatar
Sometimes getting the exact match won't work because it could've been replaced with a different setup. A picutre of your current setup can help the company you are buying it from. Also sometimes the part # is stamped on the rack as well so maybe you should take a look at it.
Old 08-26-2014, 08:15 PM
DailyGrinderEJ8's Avatar
Jack up your car and take a look at it. Or try and find a part number on your current one
VTEC junky
Suspension & Brakes
05-26-2013 10:48 AM
dsy29
08-05-2010 09:44 PM
Jdmintegr
08-23-2009 01:46 AM
soto2635
02-11-2009 08:01 PM
honda_racing101
03-02-2007 12:28 PM
Quick Reply: Rack and Pinion question!?
